Just wondering any of you that have a new 05 or know the reason behind the spec for Supreme. Is it manditory (like a Acura) or is it a sugestion. I know that in my 99 manual it tells me I will have HP differance, is this the only thing with the 05?
Silly service monkey doesn't know what he is talking about.Marc M said:I was told by one of the service guys not to run premium in my 4.0. He said it causes it to run rich causing issues with the cat. conv. He has had to replace a bunch of cats. on the 4.0's in the 4Runners for the same reason.
Marc M
I have found my mileage was better running the better gas. I have tried 87 twice and I felt that it was worth the extra pennies to put the recomended fuel in.Marc M said:I was told by one of the service guys not to run premium in my 4.0. He said it causes it to run rich causing issues with the cat. conv. He has had to replace a bunch of cats. on the 4.0's in the 4Runners for the same reason. It doesn't bother me, saves a few buck per tank, and with 8600 miles on the truck so far, that's alot of bucks.
Marc M
I didn'y really want to comment on what that tech said, My father-laws Acura, he DOES NOT run Premium. AND he does go through cats, at 180k, he has had a couple. The Acura tech said not burnin the premium causes it. FOr what it is worth. Burning premium, if the truck is with in specs will always burn cleaener.IHMOManytoys said:Silly service monkey doesn't know what he is talking about..
jayotto4 said:I have found my mileage was better running the better gas. I have tried 87 twice and I felt that it was worth the extra pennies to put the recomended fuel in.
Octane bosters are worthless. If you look at the side of the canister it ususally tells you that it will only rase the overall octane of the gas a fraction of a percent. Usually less than half a point when added to 10 gallons of gas.obex26 said:Just run an octane booster or try lucas oil. Not worth the extra dollars in my opinion I don't see much change. It does show a good option for cleaning the injectors.
It's really almost a wash. 2-3 mpg is costing the same when you add the cost of the premium fuel. Of course if it actually has more power with premium by all means use it. My 05 with a 2.7 is supposed to use 87, and I get 22-23 mpg on regular. I would have loved to have had a V-6 but 20 mpg on premium adds up to a ton of cash when you drive 25-30k a year like I do.trd2001 said:I have a v8 4runner, and i found that if i run 87, i get about 2-3 miles per gallon less. I figure the recommend it for a reason.
BMWTACO said:It's really almost a wash. 2-3 mpg is costing the same when you add the cost of the premium fuel. Of course if it actually has more power with premium by all means use it. My 05 with a 2.7 is supposed to use 87, and I get 22-23 mpg on regular. I would have loved to have had a V-6 but 20 mpg on premium adds up to a ton of cash when you drive 25-30k a year like I do.
