Supercharger HELP.........
Took my time for this 2nd SC install on 1997 4Runner 3.4L. The first TRD SC install was on my 2001 Tacoma, I had no issues and fired right up
Fast-forward to July 21, 2022, my 1997 4Runner has high miles but runs very efficient. I have a "light foot." and I am 20 years wiser since first SC.
Anyhow, upon first start up, it runs rough. Pulls code P0300. Barely started. Had to put pedal to the floor to get started and runs like a misfire.
This is what I did during install:
New NGK Ruthenium 92400 cooler plugs carefully gapped at .043 (did not break or damage tip), 93-97 Supra rebuilt injectors, new aluminum crush washers on bango-fittings for fuel rail, new intake gasket, new factory plug wires, completely removed the throttle body including running MAS air cleaner through IAC valve and reinstalled the 2 screws on the TB insuring the little rod spins freely, and installed a new fuel filter.
Since Magnuson did not mark the 1-way white valve with "black pointing to TB", I researched and the air is sucking on intake or engine side (not sure if that's right). Also, connected the hose (not supplied) from valve on back of PS pump to supplied black T-fitting to EVAP cannister/SC. Connected VSV to tiny vacuum hose that Magnuson said to connect from TB diaphragm (Pass. side) to SC side of TB and did T-fitting to VSV tiny vacuum hose. Everything else is as explained in their vacuum diagrams along with install for a 1997 4Runner.
I am lost............Help!
