Figure it was time to join some of these forums. I’ve been browsing and researching for the last 6 months since picking up my tacoma from an old family friend. At first it started with me just wanting to daily it but it is hard to keep things alone with any vehicle.
Everything is going into a 2001 Toyota Tacoma 4x4, Manual trans, j-shift t-case, 3rz. Odo reas 149xxx miles!
I started taking the cab and bed off to clean the frame which was surprisingly rust free and took the truck down to every piece I could. The frame was coated in por15 along with every other suspension component. Cross members were pulled out and all new hardware installed once put back together. If a bolt was rusted or fought me. I made it easy and cut it off or broke it off to just
Slowly I moved the to interior. Gutted it and deeply cleaned every inch then took the seat covers off and gave them a few cycles in the washer and shampooed the carpet then pressure washed it one final time.
back to the suspension I decided to go with Sonoran steel lower front control arm bushings, new Toyota Eccentric Bolts paired with a set of Durobump bump stops. The upper control arms are SPC I snagged from a local vendor. New Backing Plates went into my refurbished spindles as well as Toyota lower ball joints, wheel bearings, hubs, and seals. Marlin crawler SS brake lines and clutch lines followed after with a new slave cylinder as well. For brakes I opted for oreillys calipers and rotors
moving onto the rear axle I scored a blown TRD E-locking rear end for $100 on FB marketplace that was blown but my plan was to gear to 4.88s so Yukon gears were ordered and all new bearings and seals as well. The rear axle was also stripped, and coated in por15. New wheel bearings, backing plates, seals, drum shoes, wheel cylinders, and brake hardware including bel crank kits went in. I rebuilt the e locker actuator since a capacitor was blown in it and scooped a yota masters wiring harness to have independent control of the rear end as I please.
A Yukon triple drilled flange and ECGS solid pinion spacer found their way in as well
