1 - 11 of 11 Posts
Here's the before & after's! OTD at America's Tire for $670. Good thing I called around. Almost paid $870 at the local Tire Factory in Battle Ground.
2004 SR5 TRD w/dr spacers up front, stock rear.
Cooper STT 265/75/R16
looks awesome... at least 100 times better than with the stock tires
Looks great! You'll love those tires - I do! ...Best tire I've ever run. I'm going to try to get my wife to put these on her Tundra when her current tires wear out.
Mr.T said:
was that you doing donuts with your gray wire mod.............tires look great
No burnouts for me. Must have been those "drifters" we have over here.
***I knew, as soon as I uploaded those pics, someone would mention those burnout marks.*** :D
Tire pressure is 34 all-around.
MysticGold04 said:
Just curious, what are your f/r pressures set at? mine are 34/32.
To get mine to wear even with 32X11.5 tires, it takes 32 in the front and 31 in the rear...
11k miles later it's wearing straight across no problem.
Best way to determine tire pressure? Scribe a line on the tread. Drive straight on a flat road and hop out and check the line. (You only need to drive about a carlegnth). The line should wear even across the tread.
drifting with gray wire? hmm sounds enticing.. but considering I'm tippy, and have two dif. gear ratios... I don't think that's going to happen anytime soon for me... nice tires though, they look BEEEEEFY esp. before and after pics.. congrats...
1 - 11 of 11 Posts
