MY truck:
06 4x4 access cab TRD
Uses:
-Its my daily driver (highway)
-Construction mud, dirt and gravel. (Work site)
-Light off raod
EDIT TO ADD:Tire size 265/70R16
Wear life - WL
Fuel Efficiency - FE
Off-Road - OR
Braking - B
Comfort - C
Speed Rating - SR
Load Rating - LR
Passenger - P (Laod range of SL)
Light truck - LT (Load range of C,D, or E)
Tire weight - lbs
So far in the standard tire companies: (prices are in CAD)
BFG Rugged Terrain T/A WL:8 FE:6 OR:7 B:8 C:8 SR:T LR: 111 P 39lbs $250
BFG All Terrain T/A KO WL:9 FE:6 OR:9 B:8 C:6 SR:S LR:117 LT 49lbs $265
Michelin LTX M/S2 WL:10 FE:9 OR:7 B:8 C:9 SR:T LR:111 P 40lbs $260
Michelin LTX M/S2 WL:10 FE:9 OR:7 B:8 C:9 SR:R LR:123 LT 46lbs $280
Michelin LTX A/T2 WL:8 FE:8 OR:10 B:8 C:7 SR:S LR:111 P 40 lbs $260
Michelin LTX A/T2 WL:8 FE:8 OR:10 B:8 C:7 SR:R LR:123 LT 49 lbs $290
Yokohama H/T-S WL:na FE:na OR:na B:na C:na SR:S LR:111 P 40 lbs $207
Yokohama H/T-S WL:na FE:na OR:na B:na C:na SR:Q LR:119 LT 45 lbs $245
Yokohama A/T-S WL:na FE:na OR:na B:na C:na SR:S LR:111 P 39 lbs $236
Yokohama A/T-S WL:na FE:na OR:na B:na C:na SR:R LR:119 LT 51 lbs $280
For the prices listed above that puts me in the price range of some specialy tire companies like:
Mickey Thompson Baja STZ 40 lbs (#50641) For $170
Mickey Thompson Baja STZ 49 lbs (#50630) For $227
Mickey Thompson Baja ATZ radial plus 48 lbs (#5162) for $250
Dick Cepek Radial AT 52 lbs (#12065) for $250
Pro comp Radial A/T (#160265) for $206
I use to have the yoko ht-s but I have the bfg at now. I like the bfgs way more.
Sent from my iPhone using Tapatalk
Not sure if yours has 16 or 17" tires, but look at the bighorns too. For a mud terrain they last a long time. My truck sees, pretty similar uses to yours and they are what I'd go with again. They've got pretty close to 35000+ on them now and are about half worn.
General grabber AT2 and the goodyear dura trac are my top two all terrains, that said i've had 3 sets of maxxis bighorns now and would keep on buying them if they made them is sizes larger then 35"
