hi everyone my names mike and i recently was fixing up a 93 civic. engine change over suspension mods, pretty much everything. Well it was stolen and i figured it was time to do a truck and the tacoma was my first choice. If anyone can point me in the right direction as of suspension it would really help i was looking at revtec, toughcountry, fabtech and pro comp.. what is good i am looking for a three inch lift.. and why do you also add a body lift???
thanks again mike
thanks again mike
for a 3 in. lift i had a set of cornbred spacers which it the same type as the revtek only cheaper and he is a member here.
www.CornfedSuspension.com
also there is toy tec which is also the same type.
www.ToyTecLifts.com
another more slightly more expensive way to lift is to get a set of coilovers such as saws, kings, donahoes among many others. also there are OME(old man emu) springs that replace the factory ones. all these will offer a better ride than the spacer lifts i listed above but cost a lil more.
a body lift will lift the body off the frame, doesnt help with ground clearance much but will allow you to run bigger tires which will give a lil more clearance.
hope this help u a lil, do a search there are a lot of threads similar to yours and u should find a lot of answers to any questions u have.
