1 - 10 of 10 Posts
so im going to buy chaos UCA'S and the extended DR coilover's. other than the Tacoma Steering Rack Urethane Bushing Replacement Kit, are there any other things i need to do to my trucks alignment or anything so i can ensure that nothing goes wrong after the installation?
TTORA SoCal
What are the specs on your truck? Year, type, etc. As far as replacing those parts, just a good alignment after, and you should be all good....
install everything and take it into the alignment shop. they should know how to do everything there, and you shouldnt have any problems.
x3 good alignment=no probs
03 pre-runner ext cab, 2.7 litre 2wd
x3? where is that?
Discussion Starter · #7 ·
do i need to do anything to the gear ratio or anything like that?
if you're changing tire sizes then you would need to worry about possibly re-gearing. But if all you are doing is the lift you will be good to go after a good alignment. :D
1 - 10 of 10 Posts
