1 - 2 of 2 Posts
Can a non ABS axle be converted to ABS?
I'm looking at a non ABS axle from a 99 4x4 to replace the ABS axle on my 97.
Also, does anyone have a conversion chart to determine axle ratios based on VIN#s or axle #s?
Thanks for your help!
i don't think it can. the ABS axle has built-in spots for the ABS sensors. the regular doesn't. you can put an ABS axle into a non-ABS truck, but i don't think you can go the other way around.
i have an ABS axle sitting in my basement (it also has a TRD locker) and a regular non-ABS, non-TRD axle under my truck. i can double check closer for you if you want.
1 - 2 of 2 Posts
