1 - 10 of 10 Posts
I've been thinking about some ideas for a trail rig, and remembered something last night.. My dad had a ~96 2WD ford ranger that has like 210k miles on a 4-banger and a bad clutch. He bought himself what he calls a "yellow shit bug" for daily driving, in other words a ford focus that's yellow...lol.
Anyways, I keep meaning to go see him and put in a new clutch, but I got an idea instead. What are your thoughts on swapping in a taco engine/tranny/ECU and probably driveline on such a rig, and while I'm at it, SASing it? Since it's paid for and he has a new DD, dad and I can do whatever we want to it in terms of work and timeframe, that is if he's game ;)
I was thinking toyota powertrain because the 4 banger is so freakin weak and because parts are so easy to come by, not to mention the familiarity I have with the parts and the reliability of them as well. It's not going to be a rock crawler so I'm thinking a dana 40 would do the job up front. Steering would be simple once the parts were in hand too, just need a yota ifs box and frame supports so I can ditch the R&P. Motor mounts would probably have to be fabbed or bought. Naturally, crossmember too. Tranny would be stick of course, so the ECU would have to match that.
Thoughts?
Split it open-Eat it out!
it'd be easier to swap in a turbo 4cyl ford motor, svt maybe than it would be to do the complete toyota drive train, ecu, etc.
Deal Master
Honestly, I'd pass -
It's gonna cost more than what its worth.
If you plan on using Toyota taco engine/tranny/ECU and probably driveline
What exactly are you using from the Ford?
The body & frame...why? Does it offer any advantage- (Stronger frame, better WB)
I understand its paid for- but you will be spending alot of money /time to make it fit- It won't be worth it.
If you source a cheap tacoma engine/drive train- You can likely find a toyota frame /body for cheap as well.
The ford donor - doesn't really have anything to offer-
You are better off selling it and using the money toward buying a trail rig.
It'll be cheaper & easier to keep it a primarily Ford conversion
That's most likely true, just wanted to see what others thought :)
Still, would be cool as hell to have something that unique I think ;)
Deal Master
Start out with a Better foundation-
Toyota frame/drivetrain etc...... Then throw on whatver sheet metal you want.
Murderman's ToyoHeep - is a good example- It began its life as a 83 Toyota 4wd- after a few rollovers- It has a Chevy 4.3 & a CJ body.
4,3 blocks are cheap & readily available, however, once you start adding in all of the nuts, bolts, adapters, wiring..... You may have doubled/tripled the cost of the the block.
For whatever reason, your Prerunner > 4wd conversion has been postponed.
Just realize the Ford + Toyota conversion will be more costly and more difficult.
Discussion Starter · #9 ·
LET ME JUST SAY ONE THING Thanks for not letting your friends drive JUNK!!
LOL, point taken! SIR YES SIR!
I hear ya.
4.3s are fun, I used to have a S-10 that I thoroughly enjoyed driving, man that little engine had some kick for a v6.
fun
Look for a tacoma pickup with a 5 speed like the use at O'Reily parts trucks.
they usually have a million miles on them and can be had cheap....
T-case and sas...Good rig..
1 - 10 of 10 Posts
