1 - 10 of 10 Posts
concussed
my speedo quit working.
check eng lite comes on,stays on.
code reader says speed sensor malfunction.
anyone else have this problem?
What's the code?
Later,
....Mike
concussed
po500 i think
po50
concussed
page cannot be found http 404 error
concussed
aarrggh..cant get the file to open.
Dale, I had the same problem it turned out that the speedo cable broke off right where it enters the gauge cluster. Pull the cable off of the t-case and check to see if that side is broken (easier to get to) if that end is OK, the pull the cluster out and give it a look.
We have a cable where the newer ones use an electronic sender.
Steve
concussed
Discussion Starter #10
thanks Steve!
1 - 10 of 10 Posts
