1 - 2 of 2 Posts
OK, well it is time to work on my onboard system.
Essentially, it will be used for airing up tires, and eventually my Air Lockers. However, I would really like the ability to run some small air tools if necessary. This is my first air system, so please take a look at this and if I have anything wrong, let me know. This is the schematic I came up with:
Here are details on the components:
Compressor: I am looking at an AIM DC-7600. This is supposedly the same internals as a Puma, extremeair, etc, and all the research I have done seems to be a good setup for pretty cheap. A lot of street (mini) trucks swear by the DC-5000 and DC-7500, so I figure it will be good. Also, seems strong enough to be able to run tools if need be.
Specs:
Weight.......20lbs
Height........9"
Length.......12"
CFM...........4.0
HP..............3/4hp
AMPS.........24
Link: Click Here
Unloader: Link: Click Here
Water Separator: Link: Click Here
Check Valve: If I get the DC-7600 compressor, it comes with check Valve
Manifold: 7 port extreme outback. Link: Click Here
Gauge: Haven’t spec’ed this yet
Saftey/Blowoff Valve: 165 Blow off. Link: Click Here
Pressure Switch: If I get the DC-7600 compressor, it comes with pressure switch, I will simply relocate it to the manifold. I believe it is 100 on/150 off
In-Cab Switch: Probably going to make my own like I did with my lights
Tank: Looking at the Air-Zenith 5 Gallon. It is not too tall (8.5” with legs) so it wont hang too low, but 5 gallons should give me a nice supply before I have to tap into the compressor. Link: Click Here
Air Coupler: Haven’t spec’ed this out yet. Figure they should be easy to come by
If there is anything else I am missing, or forgetting, please chime in and school me. Also, if you think I am going about this all wrong, I would love to hear your opinions/input. All in all, this setup should cost me about $600.
thats how i'm doing my oba. Just gotta find a few more misc fittings.
1 - 2 of 2 Posts
