I put a 97 2 wheel drive 4runner automatic transmission in my truck and trying to find out what vehicle speed sensor goes in the tail shaft of the transmission? I need the one with the gear on it. I bought one from the junkyard that’s a 20 tooth out of 4by 4runner and it seamed like the gear was...
Hey all - just got a leveling kit installed on my 2016 4Runner TRD Pro. Cornfed 2” front 1.5” rear.
I am in the market for new tires. Currently still have the stock Nitto Grapplers on there coming to the end of their life. I have heard I can run up to a 33” and maybe a bit wider but curious if...
I have a 2001 Tacoma V6 (PreRunner) that is leaking coolant in such a way that's leaving me puzzled. There doesn't appear to be any coolant in the oil, no smoke from the exhaust, nor any visible coolant leaks. The water pump / timing belt were replaced 62k mi ago, with 185k on the truck. The...
hello,
Ive searched and decided on fluids based on guidance and availability. if you see any mistakes by all means chime in
2004 tacoma double cab 211,000 miles
3.4 V6 --------------------------------------------------- mobile1 5w-30
stock radiator--------------------------------------------...
Greetings, Got a funky one here. Just took kid's 4Runner ovet the woods and to Grandmother's for the holidays and found out that with cruise control (cc) on using either direction turn signal causes the cc to turn off. CC will re-engage fine over and over. Does control logic for both interface...
