1 - 8 of 8 Posts
Performance products.com, kartek, ORW, I think 4wheel parts would probably even have it.
DCabTaco said:
Some thing to consider when looking for a good relocation kit is one with a good hose set. That is why I went with the AMSOIL relocator kit. Haven't installed it yet, but looks like a good quality relocation kit.
Thanks for all of the replies guys!
Do you have a product number for the AMSOIL kit you got?
· Smoked Out!
I got the dual remote BMK 13 By-pass filter relocation kit. It is pricy, but I wanted to get the extra filtration from the by-pass filter. Especially since I am supercharged and the oil takes a beating when you get on the peddle hard. I was looking for a signle remote relocator in their site, but couldn't find one. You may have better luck with a different brand and it may be less expensive if you are just looking to relocate your oil filter without the by-pass add on.
AMSOIL does have a simple remote filter kit. Great hoses and connections. But in my case the fittings did not hold up well in the wheel well when faced with salt. The adaptors on the motor were pristine, but not in the wheel well. If you locate the remote filter under the battery or somewhere out of the salt, then it should be fine. It is a well made product, but I think I pushed its limits a bit.
· Smoked Out!
Hey thanks for that info. I couldn't find the actual part number for a single relocation kit, but maybe he can call and ask, or an amsoil dealer can chime in. However your input on the location of the filters is helpful. I will try to install it pretty soon so I will take all that into consideration.
1 - 8 of 8 Posts
