HI, need some input/opinions...
got a OME kit installed, heavy duty springs(with 10mm trim packers), bumper and winch. would like to get a 33" off road tire on my truck, pref 255 85 rim16. Will this tire size work on my setup? Have been shopping around a bit, but not sure which brand to go with. Any advice would be great
thanks
Yes it will work. The worst thing that would happen is you'd need to do a little trimming and hammering on the inner fender. What kind of tires are you looking for?
This is my daily driver, mostly just to and from work... a lot of off road driving, but by no means rock crawling or serious mudding. looking for a good all round off road tire. Im running bfg AT's now. don't want these again. have had them balanced a number of times. I think they might be wearing unevenly, I have vibrations around 100-110 km/h.
with stock rims:
frame at full turn
windshield washer pump
Pinchweld Mod
rear finder well Corners
ARB back plating
:2cents:
Ya got me...can you explain a little more? is there a thread on this already?
Search pinch weld mod :saw: :xsmash:
Tire rub frame at full turn :banghead:
Tire rub windshield washer pump/tank at full compression/turn :aahg:
Tire rub bed at wheel well opening corners (F&R) axle flex :saw: :xsmash:
Tire rub ARB back corner (wrap around wheel well) at full compression/turn :saw:
Keep in mind, this all only happens while Mall Running :xcrazy:
:2cents:
