I'm thinking about 3" or so of lift. Sorry if this has been beaten to death. I'm on my way out the door to work so i'll do a more thourough search in the mornin when i get home.
What are the pluses/minuses to each setup. Coils are out of the question.......i don't have the coinage for them.
thanks for the replies.
cart
cart
I have the 3" CB spacer on TRD coils. It was fine for a year or so but the factory coils have sagged and the ride is pretty harsh now. I hope to order the Hoe's soon.
Do go the cheap way out, you can lift your Tacoma the right way for $400 if you do it yourself. www.4x4connection.com for OME stuff, Summit Racing for AAL's and Autozone for some heavy duty rear shocks, I run the same setup on both my Tacomas. PM me if you have additional questions. I can supply part numbers.
what aal are you running. i want to avoid the arse in the air look. so i'm thinking i would jest need 1.5" of lift in the back. I want to go AAL because i pull a trailer with an atv and sometimes have an atv in the bed also. Shackles would wear the leafs out to quickly under these conditions. Who makes a good, reasonably priced AAL and what is a good reasonably priced shock?
