Okay so I'll be installing my lift soon and have a full OME set up for the rear, springs, shackles and shocks. I've never done this before and have a question. The leafs have a full military wrap at one end of them. Does the full military wrap go towards the front and the none military wrap on the shackle end or is it the other way? Probably sounds like a dumb question but like I said I've never installed springs before.
The military wrap goes toward the front of the vehice, also OME springs are side specific (your factory springs are this way too), the one with more arch goes to the driver side, If you can't tell the difference look at the part #'s on the springs your packing list might tell you which ones go to each side, also they require different size bushings than your factory springs
