Live4yotas said:
What year did they change the front suspension to be like the tacoma. I want one with the same setup as a tacoma in the front. Whats the earliest year they did this?
3rd Gen. 1996-02 (you also get the 3.4 vs. the 3.0).
Some consider 99-00 the best, 00 was the last year for both the 5-speed & the e-locker.
1999 the 4Runner got slight improvements: multi-reflector headlamps, fat-lip bumper (better collision performance), heated mirrors, revised center console with better cupholders.
The 2000 had revised springs that give less ground clearance (less rollover liability). 1999+ limiteds have "multi-mode 4wd" which has a full-time 4wd option (open center diff), but still lets you lock the center diff (which functions same as taco 4wd)--this new multimode 4wd became standard on all 2001+ (along with the demise of the locker and 5-speed).
1999 may be better if you're going to keep it stock...If you're going to lift it at all then consider either a 1999 or 2000.
(some info gleaned from Yotatech... it's a good source for 4Runner info)
