Does anyone have a optima battery in there truck, i just came up on a free yellow top from my father inlaw. He just replaced both of his in his H1, i have a cheap battery in my truck now and last time i went wheeling the damn battery started spilling acid out all over .
I tried to put the yellow top in my truck today and came to find out the the positive and negative post are backwards & if i flip it around my cables arent long enough to reach the battery posts also the battery isnt tall enough so i have no way to hold the battery down. so i had to put the old battery back in till i figure something out.:confused:
truck ~n~ tow
This has been covered alot...
Search Optima and/or battery...
You will need to make some mods to make it fit...
You could mount it on it's side... the terminals will reach then... yer going to need to form up a new hold down for that...
" could extend the battery cables and ground...
does it have both top and side posts or just top posts? There are different versions of the Yellow Top.
I was able to make the stock wiring reach the side posts, even though the terminals were backwards.
