1 - 8 of 8 Posts
Can someone advise the height of a stock block for rear of 02 DC 4x4 TRD? I fear that the truck I just purchased has been improperly lifted. The current blocks are 2.75" measured from back, and taper to a 2.5" at front.
Where is best place to find stock block if the above is aftermarket?
Found Revtek spacers in front...however the rear sits obviously higher than front.
thanks for the help
There are no stock blocks!
Stock
Was afraid you'd say that! That makes it easy to correct then I reckon...or I can get a 1" block which may level it off better. Chevy's have a stock-block on rear and I did not know if toyota did too. Thanks for the assist.
Evil
That's what I read... I understand a little about axle wrap and damage. Back in the day; blocks and re-arched springs were it. But you can bet I will get the blocks out from under the taco after work tomorrow! thanx
NorCal Chapter Pres
If you want to put a 1" block, ditch that idea and get some Deaver 1.5" 3leaf AAL...
I had 2 inch lift blocks too which sucked. I dont understand why they have those giant blocks in the big dodge pickups stock, those things are like 6 inches. Dont they cause damage too? Is it just poor engineering?
They probably do it because its cheaper.
1 - 8 of 8 Posts
