I'm wondering if I can use the stock axels & outer cv joints as trail spares with this kit? 01 dbl cab trd
I wanted to reply saying that as well but I wasn't sure if he meant stock manual hub CV and axles.grillmasterp said:To my knowledge - the kit includes new shafts & outer CV's because the ADD outer CV's & Shafts are different than the Manual hub outers & shafts-
The only thing shared between the 2 would be the inner CV
Basically if you have manual Hubs or convert to Manual hubs- The ADD shafts & Outer CV joints are useless to you as spares with the exception of the inner CVjoint/tripods
You have to remove the old hub from your old spindle with the ORS kit. You can reuse the old knuckle (spindle) because they are the same. Buying salvage parts lets you skip the hassle of pressing out the old hub when you buy the whole thing assembled.Matt said:IWhat do they do with that kit that you don't need to get the spindles from a manual hub taco? I changed mine out with all stock stuff, Aisin hubs, off of a '00 that had manual hubs and was told I needed the spindles as well. I don't see that they have spindles in their kit.
