1 - 18 of 18 Posts
I am currently running 3" CF spacer lift and 33x1050. I am also having to add a 1" body lift to resolve some rubbing issues. Therefore a custom bumper and and hard mounted winch are not in the picture for me.
I going to add two receiver points to the front of my truck. Mainly for recovery points and possible for a removable brush gard. I have also thought of using those point for a portable winch if I get in a bind and I am in need for self recovery.
So Here is my question. Would you use a cheap no name 8000lb winch from Harbor Freight, a 6000lb winch from mile marker (or one of the other popular ones) w/ a snatch block or two, or just keep a come a long and a cell phone in the truck. Keep in mind these two winches cost about the same $300-$400, and that if I had to spend more than that I would just make sure I took a friend (which I don't have any, :D not with trucks that they wheel anyway). Also the winch would stay in my tool box and not out in the elements.
Thanks,
Brad
Too much weight with out replacing front suspension.
· Retired
With a winch, you'd be correct, but with a properly built multi-mount winch setup you could have a custom bumper with a receiver and use that for winching. The bumper could be designed for winching.
A tube bumper alone will weigh well under 100 lbs.
Mine weighs about 70 lbs.
The receiver points that I am planning on adding will be welded to the top of the frame ends. They will go through the gap in the valance with minor trimming. I wouldn't think that using one of or both of these points to winch from would be different than using a bumper with a incorporated receiver. Especialy if you put the winch on one side, used a snatch block and and hooked the cable to the other.
But I am new at this and I am asking for opinions, so please tell me if I am wrong.
Brad
· Retired
Brad
When you say frame ends, do you mean the frame itself or the frame horns?
Why I ask is because the 98s and 99s had frame horns that are bolted on.
The snatch block idea is good.
Sounds like you have a good plan so far.
Discussion Starter · #7 ·
I have a 99, I will have to check on the frame horns I may need to alter my design.
Brad
Discussion Starter · #9 ·
Now that the mounting point is quasi resolved. Does anyone have comments on the original winch question?
I suggest staying away from the Harbor Freight Winches. I would go with the MileMarker or another American name brand winch.
Harbor Freight imports 99% of their stuff, and my experience with chinese electric motors, ie two of them has been less than successful, so take that for what its worth, I got what I paid for.
I noticed a 8K milemarker in the classifieds section used, here for $325. That might be an affordable option if a Milemarker is what your looking for.
I'd say just add an easily available single front receiver and get a Warn multi-mount. It's only going to be a few hundred more than the setup you're talking about, but you're going to get much more out of it. If a no-name is going to cost you $400, wait and spend the extra on a Warn. One of the worst mistakes we all make, is trying to do things the cheap way. There is so much truth to the saying that you get what you pay for.
Just my opinion, good luck.
KO
AK98Taco said:
Why is a custom bumper not in the picture?
I would be wary of winching from a simply recovery point or a bolt-on brush guard.
:confused: ....Don't most custom bumper bolt on???? I have a bolt on warn tran4mer kit that is great and strong! I feel pretty good about pulling lots of weight with my portable warn winch!!! No problem there!!!!!
· Retired
I should have said "screw on". How about that.
My front bumper is bolted on, but it's also made out of 1 5/16" schedule 40 and 1/4 plate steel, with grade eight hardware. Weighs around 70 pounds and it's extremely rigid.
A light weight brush guard hardly compares to a tubular steel bumper like those from C.B.I., Demello, Off-Axis.
It all depends on what you what to do with your front end! I'm not looking to take out any brick walls...I would love a nice heavy bumper like yourself but dont have that kind of $$$! Did you have to get heavy springs for the front??? Got any pics? Who made it etc?
By the way..That warn brush guard will put up a fight!!!
· Retired
Brick walls, LOL! That's what I feel like in this tank, err, truck.
It's a fairly heavy bumper and the suspension is paying the price as in I've lost some lift. Just spacers stiffening the coils.
Nice ride!
1 - 18 of 18 Posts
