1 - 10 of 10 Posts
I feel as though my truck is loosing power. When i put it in 2nd gear it seems to be extremely slow in the first half of the gear. Could this be me needing to change my timing belt? I am also looking to add power, supercharger, intake? Any suggestions would be appreciated
98 tacoma extended cab
sr5 v6
manuel tranny
148000 miles
never had any major maintaince done to it
Will probably get better response in the Early Tacoma folder.
Isn't the timing belt due at 90k miles? :eek:
I would do Seafoam (search "seafoam") and then replace the plugs and the O2 sensor (front)
i did the seafoam stuff and changed my spark plugs and wires. Anyone got any other suggestions?
Everything above and:
Replace fuel filter and air filter, keep using an injector cleaner and an intake cleaner at every oil change. Did you gap the plugs to .043?
Well, to check the belt, you'll have to pull everything off - may as well replace it by the time you get in there.
I meant to check the ignition timing, though - however many degrees before Top Dead Center
1 - 10 of 10 Posts
