Ok I think I screwed something up.
I blew a fuse or something for the power outlets using a pepboys type air compressor. I checked the fuse under the hood and switched with the tail light fuse and still nothing. And after I switched them back and turned the ignition, no radio. It still has power because I ejected the cd but it will not turn on.
According to this post:
http://www.tacomaterritory.com/forum/showthread.php?t=785&highlight=power+outlets
I should check the "fusible link" behind the outlets.
What fuse should I check for the radio fix?
i fixed it. i blew 2 15a fuses one under the hood (pwr outlets) and one under the dash (ACC)
from now on i will carry spares.
Ok I screwed something else up!
I switched one 15A fuse for the Radio (ACC) because i NEED the CD player, and now the ABS light is on and the AT shifter is stuck in park. I have to use the release button. what is the deal?!?!? And the power windows don’t work. All I did was swap one 15A fuse. I checked the two fuses under the hood that say “ABS” and they both look good.
What would cause the ABS light to turn on and lock the shifter?
Any help will be appreciated. I will post an update after my lunch at autozone and a box of fuses.
