I have a 2002 Tacoma double cab pre-runner automatic (the only option) with the 3RZ motor I am going to convert to a manual 4WD over Christmas break. To do this, I have just purchased a 1997 Tacoma 4WD reg cab, 5 speed with lock out hubs that was rolled. Everything looks good in the donor vehicle including the spindles (which was a concern because of the roll over).
It seems I have every part I could possibly need because I have a whole donor truck, minus the front half of the rear drive shaft, but I have some questions.
Should I have a custom rear drive shaft built from one of mine or just go find an extended cab rear shaft? I would like to eliminate the carrier bearing if possible, and of course money is a concern.
I plan to rebuild the hubs (basically a disassemble and re-lube), replace the CV boots if needed, and replace the clutch if needed (perhaps just do it anyway). Am I missing anything?
Would it be easier to run the 2002 computer (with CEL) or rewire to the 1997? I have read the truck will run fine (no limp mode) with the automatic tranny removed, but what do I need to do to make the cruise control work with the 5-speed? Would it be best to find a 2002 3RZ 5 speed computer and would the wiring plug right in?
Is there anything else to look out for or be aware of during the conversion?
Thanks in advance...
PS- I'll take pics and post them when I do the work because I haven't seen a DIY for the 3RZ conversion to a W59.
