1 - 20 of 45 Posts
Moderator
well, im in frankfort ......picking up
2 transfer cases.....i dont know what to do with them tho....any ideas/
Give one to me for my doubler setup of course! :missingto
Moderator
that is exactly my plan...picked up a top shift and front shift from a guy. plan to build them outside of the truck and then install them.....mayb when i do get these u may want the one currently in my truck.
Moderator
To do list, not in order yet:
1. Swap front springs, previous owner put driver on pass side and vice versa!
2. Purchase Rear locker
3. Fab sliders,bumper,bed cagecage
4 . Dual case with twin sticks---both cases are here......
Moderator
ok, list changed quickly....saturday i will be picking up a dual kit including everything but driveshafts and my forward shift case......guess this will be my first mod on the truck
Moderator
update:
trail-gear dual adapter-new in box
trail-gear twin stick kit-new in box
trail-gear dual case crossmember with 2 v6 tcase mounts
2 topshift cases and 1 forward shift case
all sitting in garage ready to begin transformation
Moderator
Nice! I can't wait to get wheels on this thing and try my duals out. I am more itching to try those than the whole new axle, lol.
Can't wait to see this thing transform.
Moderator
crawl box is built...woohoo...now to start the driveshafts and the tunnel modifications
Moderator
Discussion Starter #11
Twin sticked case completed...ready to mate the twin stick case and the crawl box now. Then driveshafts and floor mods
Moderator
Discussion Starter #12
well....according to pirate on an 84, long wb pickup going to dual cases, a rear driveshaft out of a 3rd gen 4runner will bolt right in....this is great, no getting driveshaft made,and has double cardan joint and gets away from a 2 piece driveshaft........
so, today i picked one up for 50 bucks!
Moderator
Where did you get it and are there any more? I need another for my sas
Moderator
Discussion Starter #14
there is one in frankfort....but they want 100. on a 98 765-258-3026
Moderator
Well thanks. I am looking for local to me or someone I know for now since gas getting there and back would be another $100 lol
I gotta wrap this up low-budget stylez
I am reasonably sure the third gen 4runners use the tacoma pattern on the flange meaning that while length may be right it will not bolt in
Moderator
Discussion Starter #18
guess i will find out....if so the guy on pirate lied when he said it was bolt-in.
Moderator
Discussion Starter #19
fud- you are correct....my diff flange fits, the tcase flange does not. the bolt pattern is wider on the new shaft....thanks for the info, i will need to figure out a remedy. tcase is still out so may look at changing output flange or mayb ??????
Moderator
Discussion Starter #20
ok, new to this shaft, so fud or mark.....which end goes to t case? slip joint or the double cardan? i think its the d/c but wana be sure before i start pulling flanges off
1 - 20 of 45 Posts
