1 - 20 of 54 Posts
So I was hanging out in the garage today and decided to fab a few wing nuts! All I had to do was take off the sway bar, chase the bolts with a dye, and then weld the nuts. It took all of 30 minutes to do....any takers? ;)
Cool mod, well done!
looks nice
good fab work.
nice, do they hit anything when you are driving?
Awesome, I like the simplicity of the design! What kind of improvements are you achieving? and the most important question, how much are you going to mass produce these for?
seriously, if you decide to fab a few more sets of these, put me in line. I'll buy one set from you.
I support the small business retailer:D
your kidding right? You use a nylon one and it would melt - you use a metal lock and turning it by hand would be real difficult.
I say ditch the the bar - total PITA IMHO. Not to metion what do you do with the bar once it's disconnected, stuff it up tie it off - great then it rubs the brake line. I tried for a long time to keep mine, finally got tired of the hassle.
the only thing i can recomend is to make the nut a lock nut
nah id want something there, at least a lock washer
but yea just lose the swaybar altogether
They make lock nuts without the nylon insert, typically called a "D" nut. :2cents:
Discussion Starter · #18 ·
A lock washer might be a good idea, but I agree that a "D nut" might be too difficult to remove even with a large wing nut such as this.
yea lock washer would work as long as it wasn't real strong and a good idea if a guys gona keep that junk :D
I agree and I think "that junk" is a good idea while on the pavement to and from the trail. Might help keep you and everyone else alive. :)
Yes such as the metal lock nuts mentioned above, but thanks for the technical term. :)
What about the bottom as it is still connected?
Most quick discos remove the entire end link top and bottom.
:welder:
On the truck that I was working on it seemed pretty easy to zip tie the lower like out of the way and it did not interfere with the suspension travel.
I appreciate all the comments and ideas. I might try a "D nut" version just to see how hard it is to remove. :) Keep the comments coming.
After a "D" nut has been on and off a few times it will loosen up, but not generally enough to come off by itself and even if it is hit it won't move far, which is unlikely anyway. Personally I see nothing wrong with the way you have it now. I used to have mine zip tied down before I removed them a few years ago and also had no issues. That's my .02
How hard is it to tighten the wing-nuts BY HAND until the bushings start to "bulge". Some of us like our ride to be sway-less while on-road. If you can't get it that way by hand I don't see the point. All you need anyway is a ratchet and the 14mm socket.
1 - 20 of 54 Posts
