The auto parts store down the road only has the Redline 75W90 gear oil in stock. Will this work over the MT-90 that everyone seems to be running?
wut?
MT-90 is designed to be used in the transmission. Most people run it in the transmission, and trans case. You want to put 75W90 in your diffs.
On the Redline website it says their 75W90 is for both diffs and trannys, so whats the diffrence between 75W90 and MT-90 is this case?
supposedly the mt 90 has added proection for your tranny. i used this same setup, mt in the trans, and 75w90 in the diffs and tcase
The MT-90 is a GL-4 and that, in MANY tests and opinions, works better in the Tacoma transmissions, than the GL-5. It's safe for brass synchros because it lacks the reactive sulfurs found in most GL-5 oils (which cause damage).
