1 - 3 of 3 Posts
Need some help ya'll. When I come to a stop light after truck has been running, it will begin to idle at a very low RPM to where it almost seems like it is going to stall. Today, I went to restart it after it had been running and it didn't turn over right away like usual. Could it be the plugs or bad gas (H20 in the gas) or something else. It has no problem starting when it is cold. I actually have a remote starter and it starts no problem.
What do you think about a dirty air filter. I have an AMSOIL with about 10000 mile on it.
Help!
Try the easiest things first (plugs, wires...) then go from there. How about your fuel filter? Have you ever changed it? Maybe MAF needs cleaning...or just needs the idle adjusted.
Fighting a similar problem. Changed plugs, cleaned MAF (take it out to clean it), Throttle Body, Idle Air Control Valve with some progress but not there yet. Starting to notice an exhaust leak, taking it to the dealer as soon as I get the extended warranty transferred to me.
Good luck
1 - 3 of 3 Posts
