Will I have to relocate the BPV bracket when I install my 1.5" deaver aal?
Why would the drums wear out too fast? If you don't extend the BPV bracket, doesn't that -reduce- the brake pressure to the rear?mudferret said:You don't have to, but it's a good idea and will save your drums from wearing out too fast, rear brakes are much harder to service than your front ones. I'd recommend doing it, cheap and easy.
if you have 1 1/2" of thread on that adjustment rod then no. Just make an extension bracket for a couple bucks; you'll want to lift it higher eventuallyGodwinAustin said:Will I have to relocate the BPV bracket when I install my 1.5" deaver aal?
