just wondering if 31x12.50 15x10 rim ssr swampers fit on a 2 in susepnsion lift 98 tacoma 4x4 v6 (not trd) or same tire situation but instead of 2in susepinsion lift, its 3in body lift??
It could fit, How tired are your coils? Each Tacoma fits tires differently. You would have to put it on the truck to get a definante answer.
Probably the worse case scenario with either lift is a little pinch weld bashing.
I think with a 3" body lift you will be good a lil bumping from time to time but not bad I would think. I had 31x12.50x15 thornbirds on 15x10's on my truck stock they hit like a mofo but I believe with 3" you would be good.
3 inch suspension on my 2004 double cab still rubbed, but its heavier than your truck. The 3 inch body will give a lot more clearance than a 2 inch suspension.
