I recently installed a Sirius plug and play unit in my truck and had a need to remove the radio to access the antenna plug in the back of the radio.
Procedure is to carefully pry forward the heat/air control panel. It is secured in the dash by four corner anchor pins. Once this panel is pulled out a little, you will see four screw heads, I think they were 10mm. Unscrew these and the radio will now slide straight out with the face plate intact. I then used a switch box from Audiovox to patch in the FM out lead on the Sirius cradle to the radio antenna jack. This is the best you can do with the factory radio to an Audiovox plug and play unit. This setup eliminates broadcasting the FM signal to your antenna.
For the Sirius radio cradle mount, I custom fabbed an aluminum bracket, painted black and secured it to the bottom of the cup holder tray (See pic).
