Yeah bro, I'm running that way.......originally to gain an inch of wheel base, but turned out it helped clear my tires from my pinchweld....YUNADERIS said:anyone running this setup with success?
have some pics to show?
drag link and tie rod issues?
thanks in advance
send it to me at [email protected] and I will put it up on my webshots site for ya.....YUNADERIS said:i ran short side forward and center hole on my perch...totally hit...didnt work out....fucking sucked..running shakerbuilt hy steer arms
i would post a pic if this site would let you have pics larger than 20k....weak shit
good call. I may end up going to standard crossover aswell.generalee7 said:Anthony,
I was thinking why not just run standard crossover steering?? I see no issue as long as your tie rod is BURLY and I'm sure that isn't hard to accomplish. I was thinking about doing this once I do 37's just to keep the tires out of the shits. Here is the setup I'm thinking about- 44044's short side forward, run standard crossover steering with a burly tie rod, lower the truck some for a better drag link angle, fab up a panhard bar, mount the ram assist to the axle end of the panhard mount and have the ram protected by the burly ass tie rod. How do you feel about that??This way we wouldn't have to mess with changing the position of the box and can run bigger tires without worry of the drag link and tie rod interfering, I mean, people already run regular crossover with no issues, as long as its setup right, right?
Screw that! All you need to do is coilovers and 39" IROK's, ToddPappaF2 said:good call. I may end up going to standard crossover aswell.![]()
are you talking about the TR hitting the center pin? if so drill the arms out for hiems and run a misalignment spacer in there. i forgot to add that point about mineYUNADERIS said:i ran short side forward and center hole on my perch...totally hit...didnt work out....fucking sucked..running shakerbuilt hy steer arms
No, he means the drag link and tie rod interfere.zszac111 said:are you talking about the TR hitting the center pin? if so drill the arms out for hiems and run a misalignment spacer in there. i forgot to add that point about mine![]()
