So I finally got around to installing a 3" lift which I purchased from a fellow TTORA member last month. Unfortunatly, the brushings on my Rancho AAL's are a mismatch to the ones on my Bilstein 5125 shocks. Does anyone know the correct Bilstein shock I would need to get in order to make this work? Any other suggestions? Thanks for the help!
Banned
a rancho AAL (add a leaf) isnt the same thing as a bilstein shock. i think you just mispelled bushing, but AALs dont use bushings. hope this helps;)
Yes, a typo there I did mean bushings. I think I solved the problem though. To properly install the Bilstein's I will need 4 3/4" bushings instead of the 4 5/8" bushings with which they are currently equipped with correct?
