1 - 13 of 13 Posts
· Premium Member
WILD YOTE said:
I relocated my turn signal lights tonight and now they blink twice as fast as they did before. The only difference is I replaced them with LED lights. Think thats it? Any remedys??
Yes, it's definitely caused by the LED lights. They don't draw nearly the current of a conventional bulb, you need to put a load in parallel to get things back the way they were. I would have to double check, but something in the range of a 6 ohm 50 watt resistor should work.
Later,
....Mike
just search online. if you don't know what resistor to get from radio shack, there's a bunch of places that sell resistors for led bulb replacement.
WILD YOTE said:
Plus it will be harder to tell if I have a signal light out next time a bulb dies...
or not...maybe it will blink even faster with a bulb out. you'll have turn signal strobes
you could always leave it like that. guys with the Honda civics actually buy crap to make it do that. just think if you had a Civic you'd be up like 15 HP with it blinking that fast ;)
1 - 13 of 13 Posts
