1 - 10 of 10 Posts
I've searched and searched and I can't seem to find anything that will tell me which rear axles will work for an 05 double cab. I've got a bent passenger side rear axle and I'd like to replace it with one from a wrecking yard but no one can seem to find anything that will work. Am I stuck having to use an 05 double cab axle or will other years work? Thanks
All tundras from 99-06 will work even sequoias. I've heard T100 rear axles are the same width as the tundra/sequoias as well. The main thing you need to look for is ABS/non-ABS. The ABS axle shaft housing has a section for the ABS sensor, the axle shaft on an ABS model has an additional gear for the sensor. Otherwise, the axle shaft themselves are the same.
I found a shaft from TAP Recycling (only place I could find one) that was specific to an ABS model. I removed the gear and it has worked fine.
All the wrecking yards said I need an 04-06 shaft and no one has any. They have offered me the complete rear end for $2K. I've got my axle at a machine shop to see if they can straighten it out but if not, I'll just get one from the dealer for $325.
1 - 10 of 10 Posts
