1 - 15 of 15 Posts
Well I finally got all the stuff I need to build the rear end. Plans are deaver 62's with a cantilever setup. 10 inch SAW 2.5's all under the bed. Here is one of the cantilevers, still needs to be cleaned up, but you get the idea.
Discussion Starter #2 (Edited)
A buddy designed everyting out on solidworks, shoud pull a clean 18 inches of travel. Planning on adding a few extra crossmembers as well while the bed is off.
Discussion Starter #3 (Edited)
Here is how the truck sits now. Camburg LT front end with 8 inch SAW's up front. Bed has since been painted and it now has the stock alloys like Tweeters truck has. Fab work done by BTF Fabrication. Brandon lives like 2 blocks from me.
Well, got quite a bit done today. :D The hangers, and shackle mount are tacked up and everything cycles great. Tomorrow's plan is to knock out the shock mounts, get the cantilevers mounted and finish all the welding.
1 - 15 of 15 Posts
