1 - 10 of 10 Posts
:confused: I just bought a used 2003 V6 xtracab 5spd SR5 with a revtek 3"front spacer lift and the rear has a block between the axle housing and the leafs.I want to
get rid of the blocks and get just an AAL or a new set of springs,can anyone give me any recommendations.I am running 285/70r16's with no rub and I am happy with the suspension clearance and no rub yet.Any help will be appreciated.
don't get fagtech's they squeek like big dogs eventually their not tapered and they don't come with anti friction pads which would eliminate that squeek . Downey for a little more tapered-pads spring. clamps . and I think they may even be powder coated
But if you go with fagtech's I recomend doing some mods to them prior to install unless you like your rig to sound like an old ford every time the wd-40 wears off
You from Lafayette Indiana?If you are was wondering where you go wheelin' around there?Thanks for the input.
Banned
if you carry weight in that truck or pull trailers, i have a brand-new Downey AAL for cost (free shipping). it provides 2" lift and 500lbs of extra carry load.
Discussion Starter · #7 ·
You are selling it?If so how much?
Hey scootn2nature, I'm up here in West Lafayette for school...is there anywhere to go wheelin up here at all?
1 - 10 of 10 Posts
