Got a big decision to make right now. Got some money for Christmas and I actually have enough to buy either one. The problem is which one? Suggestions would be helpful!!
A locker will get you through times of no flares better than flares will get through times of no locker.Crazydawgb said:Got a big decision to make right now. Got some money for Christmas and I actually have enough to buy either one. The problem is which one? Suggestions would be helpful!!![]()
pot will get you thru times of no money better then money will get you thru times of no pot!!!elgecko said:(BONUS POINTS: name the obscure reference I just paraphrased)
Definatley go with the locker. It will be much more helpful offroad then flaresCrazydawgb said:Got a big decision to make right now. Got some money for Christmas and I actually have enough to buy either one. The problem is which one? Suggestions would be helpful!!![]()
ABSOLUTELY, you win!!!grumpy said:pot will get you thru times of no money better then money will get you thru times of no pot!!!
did I win?????![]()
I'd say the locker if you're offroad a good bit. Cause, like every1's said, it'll get you thru more than some damn flares. Even though, flares do look cool!Crazydawgb said:Got a big decision to make right now. Got some money for Christmas and I actually have enough to buy either one. The problem is which one? Suggestions would be helpful!!![]()
WINNER! Dude, you're old!grumpy said:pot will get you thru times of no money better then money will get you thru times of no pot!!!
did I win?????![]()
I have a used set of TRD flares for sale, replaced with cutouts. godd shape some straches. sure then can be sanded out if wanted.Crazydawgb said:Got a big decision to make right now. Got some money for Christmas and I actually have enough to buy either one. The problem is which one? Suggestions would be helpful!!![]()
If this is your daily driver, I say buy the flares, and save for a selectable locker.Crazydawgb said:Bump for this last bit of info before I order it!!
fit good. only trim 1" fro mfront and rear of the rear wheel wells and 1" from rear of front wheelwell. I actully trm more like 1.25-1.5". and the trimming only goes up to the 3rd and 4th plastic mount holes from the TRD's.98 Taco said:Grumpy, how did the cut out flares fit
did you trim the fenders a whole lot?
I want to see pics
BTW, congrats on the SFA swap!!!!
cya in March!
Yep, here is cheaper. Talk to Alex or Bobby at PORC and they will hook you up. Also the part# 1615... www.performanceoffroadcenter.com . Tell them you are with TTORA .Crazydawgb said:Ok, It looks like a locker it is. Is there any place cheaper than this, also is this the right lockright for my truck?
http://www.central4wd.com/store/itemdetail.asp?ID=567
ATLRoach said:Yep, here is cheaper. Talk to Alex or Bobby at PORC and they will hook you up. Also the part# 1615... www.performanceoffroadcenter.com . Tell them you are with TTORA .
