RENEGADE76254 said:
well with air locker u need air compressor, that requires a few more mods than a e-locker right?? what do u mean about same money, i seen arbs for about 900 and then air compressors i havent priced. and hopefully an axle swap from the junkyard would run 500 or so. then i could prolly get some electronic parts of the wrecked truck so i could install it.
The TRD rear axles (Complete - Drum to drum) I've seen go for about $600-700 - Have you priced out the factory RR DIFF switch- Its like $40 bucks alone-
http://www.rocky-road.com/airlocker.html
Retail price on the locker is $700 & $200 for the compressor-
I looked around for a TRD rear end and even came across a couple for pretty good prices- However- Its really hit or miss when they are used.
I bought my rear locker & compressor both for Less than $700 Brand new from another member.
So I am quite pleased- ARB basically includes everything in the box that's required (If you don't need to regear)
plus I have an available air compressor- (use it to air up my wifes vehicle
The install of the air compressor is very straight forward- plus ARB did I nice job on prepping the electrical harness & relay - They only thing to decide is where/how you want to run the air line and where you want to mount the switches.
Now my trucks ready to "drop in" a front ARB locker
