1 - 3 of 3 Posts
it has been a while since i set up my e-locker but i believe that i started off with .075 an ended up using a .085.
are you sure you have all the bearings seated and are using the proper races? it is possible that one side of the bearings are not all the way seated and that is messing with your bashlash set up. i have never had issues with backlash, usually that is the easiest part to line up.
post a few pics and we can see what you have going on.......
no i used nitro, i have a few friends that are running the creepers but not on e-locker carriers.
give the .070 and .065 a shot and see if that gets you in the ball park. are you using a crush sleeve? are you using a set up bearing?
the only thing that i can think of on the backlash is that you are cross threading. i have done this a few times and it will bottom out on one side and not apply proper pressure.
good luck!!!
1 - 3 of 3 Posts
