Hey guys.
Some of the holders for the mini ATC fuses in the fuse box are hnot holding the fuses right. I was looking to get some replacements that will replace the stock ones.
Anyone know where I can get some replacements that I can just slip into the fuse box and connect the wires to it? Toyota?
Discussion Starter · #2 ·
Anyone?
Can you just crimp the contacts tighter with some needle nose pliers?
I think I may be fine. Looks like there is a spare slot in there: Fog lamps
I don't have fog lights, so it's not used, but the terminals are just chillin in there.
Looking at it, there is a spot for FogLamps that is empty, but there are wires going in the cab, colored Blue with red stripe, and white (I think that being the battery source)
Think I'll have a problem cutting the clut and red stripe and splicing whatever wire need into that connector to replace the bad one?
Discussion Starter · #7 ·
Did it, works just fine....
Be careful soldering though! Have it angled towards the wire. I learned the hard way. Luckily I was able to salvage it.
