Anyone have any write-ups on how to change both the Idler and Pitman arms on a T100? both of mine have seen far better days and I need to replace them. Thanks in advance!
Finished replacment. Idler arm went smooth, thanks SC T100 for the link, def helped. Struggled with the pitman arm and had to bite the bullet and take it somewhere to get replaced
next time you have to do this if you buy a small puller (like a pully puller for a lawnmower) and hook it over the arm put a little tension on it and smack the pitmar arm with the back of a big ballpein hammer it will pop right off
I just installed a 2 inch ball joint spacer on my 1997 toyota t100 sr5 I do need to get new shocks on it but my upper bump stop is on the control arm but it been like that since I bought it i have tried lowering the tortion bars but it does not go down any also the truck rides really rough...
I picked up a 1st gen TRD supercharger that's been modified to hook up to an intercooler. For the life of me I can't figure out where I should put an intercooler on this thing, or which one to buy.
I picked up a CX-Racing air-to-air intercooler that's meant to fit a 5VZ-FE, but there's nowhere...
Everyone I spoke to said they didn't have anything that would fit. Doing searches in all the other forums provided nothing. The only option there was if yer OEM rubber steering rack bushings were soft/worn/loose was to replace the entire rack. The "D" ring bushing is the only dealership option...
Okay probably a real dumb question, are the CV axels the same length both passenger and driver side?
I just finished building a LT kit for my 4runner and need to order some axels but I can’t find a damn answer anywhere if they’re the same length but all websites only have one option, which...
Hey guys, I just purchased a 95 t100 and am having some issues with it. It will crank and idle with no issues. When i rev the motor both driving and while in park it will bounce between 2200 and 3000 rpms like it has a miss or is hitting a rev limiter. Any advice on what to check or possible...
