alright, attempting to install my donahoe bumps in the rear on tuesday and i need to remove the stock bump stop pad on the frame which requires me to "drill and/or grind" the 4 rivets on each side to remove the pad. now heres the question. what is the proper way to drill them out? i googled it but couldnt really find an answer. should i start with a pretty small bit and drill the very middle of the bolt and just work my way up until the head of the rivet begins to spin to show ive drilled it out or is there another process? i also purchased my first angle grinder the other day, would this be a better route? yes, i realize im pretty tool illiterate, but you gotta start somewhere, right?
you just grind out the head, and you can see what size bit you need to run through the rest of the rivet. or just grind off the head and use a punch and push it out
sweet deal... so grind off the head with the angle grinder and then punch it out would be the easiest way? i was thinking drilling would take a long time since id be drilling through metal over and over, lol.
Grind the head flush and use an air chisel to punch out the slug. Takes a few minutes for each rivet and is so much easier than drilling the heads, plus you don't obround the rivet holes in the frame.
The way he asked. You drill out the side without the button. Use a bit that is the same size as the pin and it will come right out.
Related Threads
TTORA Forum
2.4M posts
75.5K members
Since 2004
