Need a right front manual hub spindle w/ good bearings for a '96 4x4 V6 Tacoma.
You are not going to find a spindle with bearingd on it. They have to be pressed in along with knuckle. Unless you are calling the steering knuckle assy a spindle.
spindle
I thought that with the spindle removed from the truck I could just swap out the hubs and replace the whole spindle instead of the dreaded bearing job.
That's a steering knuckle.
You want the entire knuckles with spindles and the hubs. The bearings press into the knuckle and the spindle/hub presses through the bearings with a retaining nut on the back side.
Good luck finding just one side though. They are fairly scarce as it is. You'd probably have better luck with the salvage folks than here.
The only way you'd get one here is if someone does an SAS but then they would want to sell them as a pair including CV axles and lock out hubs.
oh, thanx for the info. Found a machine shop nearby that will press them out/in for me. Is there an inner and outer or just one bearing?
