Tube doors are on hold for some other changes.
4.7 Tcase gears showed up and began working on the truck to get those in. Have had a leak at the back of the motor for some time now and decided to pull the Trans to check it out. My first suspicion was valve cover but I have changed it prior. So my thought was rear main. We will get to the bottom of this oil leak.
Trans and tcase out and all cleaned up. There was some build up of oil in the bell housing too thick to be motor oil. Going to reseal front of trans while it is out. Can see oil all over the EGR plate on the back of the motor. So my guess right now is not rear main.
Still need to pull the clutch and inspect rear main. Will inspect EGR area more.
