1 - 15 of 15 Posts
1984 4Runner
Trail Gear 4" springs F&R
Close to 5" of total lift
Old school All-Pro crossmember
109" wheelbase
Extra weight on the truck
Full cage, front bumper, hard top
35" Generic All terrains
33 15/16" tall at 30 psi
26" frame height
??? belly height
11" rear diff clearance
11 3/8" front diff clearance
3815 lbs (1/4 tank of fuel, hardtop, 35's)
39.5" Iroks
I'll measure it up when I swap the big tires back on.
1993 4Runner
Front suspension - balljoint spacers, no tbar crank
Custom triangulated 4 link rear w/ TrailGear housing
Budbuilt skids and crossmember
Full armor - TONS of weight
33x10.50 KM2 - actual height 32"
Frame: 21"
Lowest point crossmember: 17.25"
Front xmember/skid: 13-3/4"
Rear diff: 10.5" (13.75" under the axle tubes)
Moderator
Troy, you should measure the actual tire hight as well. this will allow fair comparisons taking into acout changes in height due to tire size, wear and pressure.
1987 4runner
Flat Belly
3 Link rear, stock front
Worn 35" BFG Mud terrains: True Diameter= Check on that.
Clearance numbers:
19 3/4" to the lowest point of the belly pan. 20" at highest.
Frame is 20 front-21" back (slopes up and to the back).
Front xmember/skid: 12"
Rear diff: 11 3/4"
I'll measure my mutt of a truck tomorrow at work and update this post with the details. Will have to update in a couple of weeks when I go to the Q78's. All I have for those currently, is @ 25psi they measure EXACTLY 35" tall.
00 Regular Cab Frame/running gear
OME Shocks/882 coils up front
OME Dakar springs out back
All pro skids
Front x-member -- 14 1/4"
Center x-member -- 17"
Rear Diff -- 10 3/4"
BALD 255/85/16 KM2's actual height @ 32psi -- 32.5"
Front x-member -- 15 1/2"
Center x-member -- 18 1/4"
Rear Diff -- 12" (unshaved diff, drain plug still in the bottom)
Q78-16 Bias ply TSL's actual height @ 35psi -- 35"
You guys want me to sticky this thread?
Also add your vehicle weight if you know it.
98 Ext cab taco
4" lift alcans outback, 14" shocks
Radius arm, 12" dual rate CO's 150lbs over 225lbs upfront
126" wheel base
extra weight???? lol
9"
d44
sliders
frame plating
spare 37
ha
compresor
37" Iroks
36.5" tall at 30 psi 28psi outback
25.5" frame height
23.5" belly height
12" rear diff clearance
12" front diff clearance
5540 lbs full tank and me
2K Tundra, V8, Access Cab, LT, 9" rear in DA housing
600x18 coils on 2.5x8 bodies
Alcan packs, +2.5"/+500#, shackles IIRC 1" longer & pivot moved up 1"
[email protected]" backspacing, 315/75/16 mall terrains
Engine/xmission/tcase/belly skids, sliders, ARB & custom bumpers
128" wheelbase
74" front wms-wms (outside of tire approx 86")
72" rear wms-wms (probably ~84" to outside of tire)
Loaded, 3500# front axle, 3000# rear axle, without carpet, rear seat or tailgate
Heights:
IFS skid-
Belly-
Frame-
Sliders-
Rear diff-
Moderator
1999 Extra Cab Tacoma TRD SR5
OME 882's
Dakar Rear Springs
2" Roger Brown Body lift
255 85 16 BFG KM1's Actual Height-32 1/8"
Front skid - 13 1/8"
Rear Diff - 11"
Mid Crossmember - 16" at lowest
Frame, 19" front 19 1/2" rear.
I will try and figure aproach/departure angles sometime.
1 - 15 of 15 Posts
