My buddy is trying to install some 4:88 gears in his 02 TRD Taco. The gears he got from Randys Ring and pinion are ygtv6-488 they are Yukon gears.
Everything is the same exept the pinion flange from the stock R&P is larger than the new pinion at the splines.
I guess the question is, does he have the wrong R&P or the wrong flange?
I'm pretty sure with the 02 and newer you need a new flange, the spline count is different I believe. I think marlin sells them, but I could be wrong.
So he most likely has the correct r&p? I could not find any info on the web with the part # he gave me.
What is the stock application for the flange he needs?
if they were the wrong gears, ie. non-trd they wouldn't fit at all...different bolt pattern and # ;)
the spline problem surfaces again...sign...Randy's knows about this and should have sent what is needed or at least told him about the problem.
don't have the flange pt# for you :(
I would think Randys would warn the customer buying gears for that application that they must get (whether or not buying it from Rndys) another flange. :rolleyes:
They called around to some shops and one guy had his shop # forwarded to his cel. The shop owner went to the shop to meet my buddy and got them the flange hey needed :xbeer3:
yea, one would think :rolleyes:
but then Randy's doesn't exactly have a great rep here.
