1 - 3 of 3 Posts
I have a 3 in ProComp lift on my 07 TRD with 285/75 R16s and they rub like hell with 1/4 spacers up front. Anyone have a suggestion to where to pick up a set of longer wheel studs so I can go up to 1/2 spacers. Also can the anytime locker mod be used on the auto transmission with the new trucks?
Sounds like you need different backspaced wheels ... did you check out the late model Tacoma forum on the national board?
Also, where are they rubbing? If it's on the fenders, pushing the tires out is going to make it A LOT worse.
If you still want spacers, check out Spidertrax in Fort Collins.
I am running stock rims. Kinda like the look of them ya know. It it actually rubbing on the upper control arm and on the frame. Not anywhere close to the body. I have 1/4 in spacers and think 1/2 will work but studs aren't long enough. Thanks for your help
1 - 3 of 3 Posts
