1 - 3 of 3 Posts
just instaled K&N S77 cold air intake ,LC Engineering headers and magnaflow exhaust with high flow cat and now it running ruff, idleing high at 1500 to 2000 and lopes i have replaced TPS, spark plugs NGK and fule filter the MIL light is not on any help TY
Discussion Starter #2
Fix
ok i i got it if someone elce has this problem first check and see if you tacoma has california emission your bank1 sensor1 is an air/fuel ratio sensor witch is different from an o2 sensor (if you put an o2 sensor it will still run like shit well at least mine did) it cheepst place i could find on is https://www.trademotion.com/partlocator/index.cfm?siteid=213804 i hope it will save other the headache and the $ i went through
1 - 3 of 3 Posts
