What's the most effective way to rust proof the uderside of a taco?
Is it allright to just spray over mild surface rust w/some rustoleum and whatnot? I need to do this as well on my minor and major frame rust problems. I've even got rust in my damn rock chips on the side of my truck....i need fender flares.Koke said:This will be the first spring that I will need to "touch up" the underside of my toyota. However, every spring I would spray the underside of my ZR2. I buy a can of Krylon flat black industrial spray paint and just spray right over any visible surface rust. It usually isn't that much since I try to do it twice a year (spring and fall). This has worked well and prevented any serious rust problems. If there was any more than surface rust I would try to remove it with a wire brush or wire wheel. I do not suggest rubberized undercoating, as it is very messy and looks like crap when it gets muddy. Throughout the winter I try to blast the salt from the underside with a pressure washer once a week. It seems like a loosing battle but it is well worth it in the long run. Hope this helps.
Now that I live in a less salted area than the Great Lakes region, I do just that.KStacoma said:Is it allright to just spray over mild surface rust w/some rustoleum and whatnot? I need to do this as well on my minor and major frame rust problems. I've even got rust in my damn rock chips on the side of my truck....i need fender flares.![]()
